I have had some computer problems and it seems recently that my dvdxcopy may work eventually but there is a lot I have to do to get it going.
My temporary solution is using DVD Decrypter to copy the DVD to the computer...and then finding the file, clicking on it (they are coming up as Adaptec files) and using ADAPTEC to burn it.
This has been working wonderfully until today I had a disc that was over 7 gigs, and it says the disc is not sufficient to burn.
I would have thought the DVD would begin burning and simply as for another disc to be entered halfway.
Is there a way to get this broken up so that I can get this DVD copied?
I want to be able to burn movies that woud normally be 2 discs, but my Nero and DVDXCOPY are not functioning properly recently, and Adaptec is my only solution right now.
THANK YOU SO MUCH FOR YOUR HELP!
Here's one way to do it.
http://www.dvd-guides.com/guides.php?category=dvdsplit&name=shrinksplit -
Always amusing when people assume the computer will make an intelligent decision.I would have thought the DVD would begin burning and simply as for another disc to be entered halfway.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Owners of Adaptec 2940UW, 2940U2W, 2940U2-OEM & 2940U2B
By ofbarea in forum ComputerReplies: 11Last Post: 28th Aug 2011, 13:29 -
Digitizing Analog Video with Adaptec AVC-3610 Dual Tuner
By washbuckler in forum Capturing and VCRReplies: 3Last Post: 18th Nov 2010, 12:04 -
Adaptec AVC-3610 Dual TV Tuner - NEED HELP!
By kookie2000 in forum Capturing and VCRReplies: 13Last Post: 7th Mar 2010, 08:56 -
[SOLVED] Adaptec AHA-2944UW WinXP Driver
By sdsumike619 in forum ComputerReplies: 2Last Post: 20th Oct 2008, 03:05 -
Onboard Raid 5 vs. Adaptec PCIE
By mike909 in forum ComputerReplies: 18Last Post: 2nd Jun 2007, 02:05
