  1. My pioneer 106 is ext and connected via firewire. In device manager it is only listed under dvd/cds as the firewire not the pioneer unit. I tried some 'check you pioneer firmware version' and it says there's no drive.
    1) How do I get around this and,
    2) How do I know which upgrade is best to use?
    thanks,
    Jack
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    i did a flash on my 104, but connected to IDE. is it possible for you to connect up to IDE? If you're worried about opening up your computer etc you needn't be, it's quite easy and we can talk you through it.
    as for which firmware is best, they should come with .txt files that let you know what they do, and say which is most current.
  3. i was able to find a prog that read my dvd is DVD-106RD firmware v 1.05.
    From my reading I believe this is an acer and can be flashed to a pioneer and than upgraded? Know anything about this?
    I will move it to an ide connection before flashing.
    Lastly what benefits are there from flashing? more media types, faster speeds, more reliable (less coasters)?
    thanks,
    Jack
  4. http://forum.rpc1.org/portal.php
    http://forum.rpc1.org/index.php
    http://pioneerdvd.rpc1.org/
    Do a little search here, you'll find all the answers to your questions
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  5. you CAN'T...
    have to connect it to a IDE port, then flash it. the best way is to use pure dos, not windows.
    the benefits, is more reliable, faster ripping, bitsetting.....
  6. Of course you CAN !
    Originally Posted by >NIL:
    DVRFlash and FireWire on Windows seems to be no problemo
    http://forum.rpc1.org/viewtopic.php?t=23679
  7. Originally Posted by lenti_75
    Bitsetting on a Pioneer drive
