I've got some music videos that i want to put onto a dvd.
They are wma/v files 320x240 pixels,308 data rate,video sample size 24 bit.
This doesn't mean a lot to me other than they're obviously not great quality.
What is the best PAL settings to use in TMPGEnc for these ?
I don't know whether to choose 352x288 or 352x576 or 720x576 video resolution.
Or what to set the average video bitrate to.
Obviously i want to convert them to the best quality i can but i don't want to have the settings too high that it takes ages and doesn't give any better results.
352x288 would probably be best. Anything larger and you'll see an increase in pixelization. Any more than 2000kbps is probably overkill.
many thanks for your help,its good that i asked because i was going to select 352x576.
Converting AVI to DVD using DVD Flick: low quality result
By e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 11:50 -
WMV files equal to DVD quality
By uniks in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2010, 11:16 -
converting down to low size yet maintain good quality
By lawlbear in forum Video ConversionReplies: 3Last Post: 19th Dec 2008, 19:06 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 18:08 -
Best way to convert a low quality WMV to DVD?
By Bix in forum RestorationReplies: 2Last Post: 20th Sep 2007, 20:08
