  1. Do you guys know of a program that would check the integrity of a CD and its data? What I want to do is have a tool to check burned CD to see if they are good. I have come across a few CD that I have burned here and the CD burned Successfully with Nero Or Roxio. Problem is I could explore the CD but not copy off it. Any suggestions?
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    That's probably the best way to check, actually. If you can't copy from it, that's a pretty good indication that there were write errors. Nero has a feature that verifies burned data cd's. Try that too. If you are using cheap cd's you should burn slower than the max rated speed. I bought a cheapo spindle of 32x discs a year ago and found it was best to burn at 16-24x to not have errors.
  3. This kinda irritated me, but maybe you'll have better luck with it.
    CDCheck
    http://fusion.zejn.si/
