I want to capture footage from a VHS tape onto my computer. I have a Geforce2 mx 400 with S-Video access in the back. It's advertised as TV-Out. Anyway, I plug the S-Video from the computer - into a video converter (s-video to yellow) - and the yellow into my VCR's video out.
That's really not the problem, though. Softwar doesn't read my video card. Am I confused? Can you even capture from a VCR with just a TV-Out card? Or is it something different?
I went into the NVIDIA settings and there's a box to check if "TV-out isn't working properly." But - nothing.
You're trying to use "TV-Out" as "Video In". It won't work. You need a capture card, pure and simple. The TV-Out is only for viewing your PC display on a TV set, like for a meeting presentation. That's all.
Is it possible to capture like this? (Videogame related)
By fathertadpole in forum Capturing and VCRReplies: 4Last Post: 20th Mar 2010, 11:47 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Looking to buy a capture card or any other related product.
By jonathan3566 in forum Newbie / General discussionsReplies: 11Last Post: 7th Jul 2007, 02:10 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
