  1. Hi all,
    I have a movie file that is a mac binary encoded file. Stuffit will not open it. Does anyone have any ideas please.
    Many thanks in advance.
    Russ
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    What does stuffit say? It should open macbinary files. Else, try MacXBinary or NutCase BinHex.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
    -> here
    maybe a .bin without a .cue?
  4. Originally Posted by ykz
    That would be my guess too. Try opening the file in VLC to see if it plays. If it does try using VCDTools X to pull out the MPEG (does someone have it mirrored?) if you need it out of the .bin file. VCDGear also has a .bin to .mpg conversion if you cannpt find VCDTools.
