Do you have any experience on any of those products? I am planning to transfer all my VHS tapes into DVD using Panasonic DVD recorder and some of my tapes are in fairly condition meaning the picture is slightly blur and little grainy from video noise. Will any of this improve picture quality? Most of my tapes are copied from TV shows and some were shot using videocamera. I would like to hear your thought before I make a purchase.
Thanks!
Your Panasonic will give you a "cannot copy protected source" or some such nonsense if you try to copy commercial tapes. Sima and govideo devices will remove macrovision but not the more robust cgms. You will need a tbc like datavideo tbc100 for about $300 or the more cost effective facetvideo video clarifier $89. http://www.facetvideo.com/
check out this post,
https://www.videohelp.com/forum/viewtopic.php?t=214003&start=0&postdays=0&postorder=asc&highlight=
Hope this helps.
Sima GODVD CT100
By kenmo in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2011, 06:29 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 13:09 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 12:46 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
Sima Godvd Availablity, What's Going On?
By ralfdog in forum RestorationReplies: 1Last Post: 17th Jul 2007, 08:50
