Just what the subject says.
Mainconcept Mpeg Encoder 1.04.01.00
I have a bunch of 352x240 avi's captured from a Canon, at 15fps.
No point in making them full D1, and framerate conversion to 29.97 seems to work allright during encoding, with barely noticable jerkiness.
Just trying to cut some encoding time off by not resizing that much.
While I'm here, how would I accomplish this in tmpgenc and Canopus?
Results 1 to 10 of 10
Cheers, Jim
My DVDLab Guides -
Why even use 1/2 D1. Why not encode to VCD spec video, 352*240 (so no resizing). After all you won't increase the quality by enlarging.
I would do VCD, but dvdlab chokes. Need dvd compliant files, or at worst, svcd. The quality of the files is quite good, and dropping to 1150kbps VCD is not what I want to do, unless there's a way to get Mainconcept to encode 352x240 vcd at a custom bitrate of 6000kbps or so.
I just don't know enough about resizing in Mainconcept I guess...Cheers, Jim
My DVDLab Guides -
Click the "Details" button to change the resolution to 352x480, then the "Advanced" button to change the bitrate. I probably isn't necessary to encode half D1 with more than 5000kbps. In my opinion using more than 2000kpbs would be overkill for VCD resolution. Once you have your settings to your liking you can go to Options>Save Settings As Template to avoid having to adjust manually every time.
So just dump the video size from 720 down to 352 and encode?
And here I thought it was gonna be complicated
Thanks Teegee
Cheers, Jim
My DVDLab Guides -
Understandable considering that most of the shit we do in this hobby is complicated.Originally Posted by reboot
Not worried about audio, had that figured out long ago.
Tried importing VCD (video stream only) made in tmpgenc, and dvdlab balks. It will take it, but that's not what I'm after.
The actual video quality is quite good, it's just the framesize and framerate that are VERY stupid (thanks to Canon).
In order to maintain quality, I encoded at HalfD1, 2500kbps (thanks for the tip teegee), and managed to author a great looking dvd. Better than the full D1 I had tried earlier, and MUCH better than VCD.Cheers, Jim
My DVDLab Guides -
Enough! The next person that says "use VCD" gets smacked :P
Might I point out that 352x240 (that's 352x288 in PAL land)is a vaild resolution for MPEG2? There's no need to encode it to MPEG1. Do it as progressive, since there's no need to do it interlaced. This is how I make those "10 Hour" DVD's for the kids on those loooooooong summer roadtrips. It's also the perfect resolution for those annoying 320x240 downloaded AVI's...To Be, Or, Not To Be, That, Is The Gazorgan Plan
HalfD1(?) to 720x480?
By hech54 in forum Video ConversionReplies: 4Last Post: 24th Sep 2011, 13:29 -
IVTC and AR halfD1 questions, converting to xvid
By spiritgumm in forum Video ConversionReplies: 54Last Post: 13th Sep 2010, 09:53 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Mainconcept MPEG-2 / H.264 refuse to encode interlaced footage
By Colmino in forum Video ConversionReplies: 0Last Post: 2nd Jul 2008, 15:23 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14
