  1. Hi everybody
    I have a big problem which is when I want to cut a part of my movie it has to start from a key frame and end with a key frame. is there anyway to ignore the keyframes? and just cut the movie by frames that you don't want?
    Dec 2002
    My Swamp
    You have to cut at key frames.
  3. Hi andy
    that's what I was saying. the problem is I cannot just cut the movie from any frame.
    But I found a way to do that (I know it's not new for you all but I'll explain a little). when I selected where do I want cut and when I wanted to save the new avi, for the Video I change it from Direct stream copy to Full processing mode. that'll do. thanks anyway Andy
    Mar 2004
    London
    Go into the properties of your capture codec and change settings to keyframe every frame - not all allow this, but some do such as Picvideo Wavlet 2000, then you can cut at any frame perfectly.
