Hi,
I have the NEC ND-2500A DVD writer and burning with Toast 6. I have a problem with burning some movies. I burn them at the lowest speed (x2) and still this seems to be to fast as the movie jumps and freezes. Some movies works ok, but mostly not
I don't find a way to burn in x1 speed? Or is there something else I do wrong?
Results 1 to 11 of 11
Yeah, definitely sounds like a problem with bad media. This problem is on a set-top DVD player, right?
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Tried Verbatrim, Princo, Sony etc. But why can't I record in x1 speed in Toast?
In my copy of Toast, it never records DVD-R at 1x speed in the external burner, I don't know why. It always defaults to Best, which, in my case is 2x. Luckily I havent had any underrun issues since moving from Toast 5 to 6.
you can turn it off BEST and actually choose 1x
but jumping and freezing is totally up to poor media brands and a bad/cheap dvd player.
Go with TDK or Ritek dvd's and make sure your dvd player is respectable. One way to find out if your dvd player is cheap/not working well is to play that jumpy dvd in your computer. It plays fine in there then its got to be either media choice or your dvd player. Get TDK or Ritek media and if you still get jumpy playback its got to be the dvd player. -
Does it jump when you play with DVD Player on the Mac?
My DVD player is not a top player, but I think it's ok. IT's a Samsung SV DVD1E combined DVD and VHS machine.
BUT now I found a media that is working fineIts a brand called FORTIS. Should I use the + or - though? (to be compatible with other DVD players such as PS2 etc.)
My SV-DVD1E didn't like iDVD3 burned Maxell -R disks (burned using Nec ND-2500A), it had some kind artifacts. Made copy of original DVD-R, target media was Philips 4x +RW, works perfectly. But of course, iDVD doesn't show burning speed and I didn't have stopwatch. Bottomline is SV-DVD1E plays almost anything you can insert into, if media is ok
Toast 6 sometimes reports available burning speeds strangely. It shows certain speeds in italic and may not show all speeds. When you click speed selection list again, it may show everything correctly. I think there's definitely something to be fixed.... -
miksu,
Funny thing that we have the same DVD writer (Nec ND-2500A) AND DVD player (SV-DVD1E)
Do you have any other good tips to give me about the DVD player? I have installed att microvision kille chip but it wont work?
Also I have changed the remote controll 3 times now, the numbers 1-9 on the remote stop working. Samsung say's it's only me having this problem but I don't belive them.
dvd recording problem
By alrayken in forum DVD & Blu-ray RecordersReplies: 0Last Post: 18th Sep 2010, 19:17 -
By machfee in forum Newbie / General discussionsReplies: 20Last Post: 12th Jan 2009, 22:39 -
Need help with odd problem with erasing/recording DVD+RW
By fdm2000 in forum ComputerReplies: 17Last Post: 3rd Nov 2008, 18:02 -
Problem with DVD recording (corrupted data)
By cyclon88 in forum LinuxReplies: 0Last Post: 10th Dec 2007, 01:40 -
Problem with recorder? Skipping only when recording on DVD
By fastheart in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2007, 10:26
