From what I can see, I am able to block certain ports using the router.
People here, on my network, are becoming quite obnoxious with IRC, Yahoo chat, Kazaa downloads, etc. It sucks up all the bandwidth from the things the broadband was intended for .. not to mention I DO NOT approve of some of it (though luckily none of it is music, so RIAA can bite me).
What ports do I need to block to keep this crap traffic to a minimum (or altogether gone for good)?
Depending on how strict you want to be, and I remember correctly, you can block all ports above 1023. All ports below that are reserved, but all ports above that are for 3rd party applications like chat, irc, Kazaa, etc.
Ports below that are more problematic, as you could interfere with mail, news, DHCP, etc.
It's a good stance to take if you want to eliminate unecessary traffic. Just be prepared for a slew of complaints. Typically you would then unblock only those ports approved for use.
The full list of well known ports can be found here:
http://www.iana.org/assignments/port-numbersImpossible to see the future is. The Dark Side clouds everything... -
That's exactly what I've done. Works perfectly.
I did however have to open open the 3000 range for FTP transfer access to my many sites.
The people that complain can bite me.
Also did UDP 80 to block out chat.Want my help? Ask here! (not via PM!)
I just block everything, but not full stealth. Then open up specific ports I need and forward them to the computer thats going to be using them by Mac address.
Most software, p2p, IM, etc., can be configured to use any ports, including that 3000 port range...Originally Posted by lordsmurf
I have to agree with Flaystus - block all and open up what you need...
Help with usb ports?
By t_jay17 in forum ComputerReplies: 5Last Post: 4th Feb 2009, 09:33 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 13:34 -
serial ports
By rubberman in forum ComputerReplies: 10Last Post: 17th Jan 2008, 11:40 -
How to know which ports are in use on a PC?
By deanbrown3d in forum ComputerReplies: 2Last Post: 21st Sep 2007, 05:28 -
engine or ports
By gunukhan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Jul 2007, 13:48
