  1. i get this with my cut files wich i cutted with TMPGEnc
    easy cd gives me this when i loaded the file and nero also needs to re encode the mpeg
    does anybody knows what this can be and how to fix it
    thx
  2. It refers to either how it is multiplexed or the pack size.
    When you cut with TMPGEnc you MUST change the setting on the top to MPEG-1 Video-CD rather than leave it on the default "Auto".
    You can fix your current cut MPEGs by remultiplexing them with TMPGEnc (go to "simple multiplex" and again, change the setting to "MPEG-1 Video-CD&quot.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. ok thx alot for the help
