Lo ppl
Right, what i meant to say was.....
I am trying to get my head around this WinTV PVR card i've just been given and have a couple of questions.
I understand that to create a SVCD i have to capture to 480x576 mpeg2( for pal )yes? Ok. Well my PVR is the USB version and i don't seem to be able to find anywhere in the settings the abilitly to record at this resolution. I only have 4 options available 1 mpeg1 at 1150Kb, and 3 mpeg2, at 2Mb,4Mb,6Mb at half D1 (D1?) and that is IT, nothing else to play with at all. I need to record a 30min clip and i have experimented with the 4 options and should be able to use Mpeg2 2mb to create a managable size clip of about 480Mb. Only problem is the clip is at 352x576 res, ( I think, i'm at work at the mo, and my brain is to far gone to remember that much detail). Can someone point me in the right direction now pls? I would like to drag and drop this file into nero to create a SVCD but i think i'm missing something....
I have downloaded FlaskMpg, DVD2AVI, and various other utils which i have messed about with but i am kinda lost. Am i right in thinking that i have to stick with the software that came with the PVR to make use of the hardware encoding feature? Help!!
Thanks for your time....and apologies for the large post.
Specs are
P3 1000 CPU
Abit Sa6R Raid Motherboard
Hauppauge WinTV PVR Usb
1x Fujitsu 13Gb IDE66 Hdd
1x Fujitsu 20Gb IDE66 Hdd
512 Mb PC133 SDRam
Geforce 2 Gts 32Mb
Sb Live! Value
Dxr2 DVD Decoder
blah blah blah
oh and Win XP Pro
Kall
I have the WinTV PVR PCI version, to edit the resolution you go into the windows hardware manager, find the capture device (mines under legacy capture devices) and edit the properties there. The MPEG2 options your given record at full DV resolution, though I find if you want the best quality your better encoding to avi then converting.
Clarification on multiAVCHD converter...
By ranchhand in forum Video ConversionReplies: 2Last Post: 28th Feb 2011, 14:16 -
looking for some clarification on current projectors
By Seeker47 in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2009, 10:48 -
RCA Jacks clarification.
By therock003 in forum Newbie / General discussionsReplies: 49Last Post: 22nd May 2009, 23:23 -
Clarification on processor support
By seven_deuce offsuit in forum ComputerReplies: 10Last Post: 14th Jan 2009, 17:57 -
MPEG-2 Codec Clarification
By DeeBeeOZ in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2007, 16:15
