I've been trying to convert .vob files to AVI for use in Vegas 5. I've found using DVD2AVI in conjunction with the VFAPIconv plugin allows me to do the video half, but I still haven't gotten the audio to work correctly. In DVD2AVI and VirtualDub the extracted .wav files are glicthy and also don't sync up correctly with the AVI... it's close, but off just enough to be noticeable and drive me nuts.
So I'm wondering:
1.) Does anyone have any suggestions for what software I should use for good, reliable .wav extraction from a .vob file? I use Windows XP Home.
2.) I've been trying for the last two hours to get the trial of #1 DVD Audio Ripper to work on my machine but it won't. I tried the .exe file, it just opens and quits really quickly. I then downloaded the new driver as their site suggested and installed it, rebooted... still doesn't work. I then used their sysregistry updater, rebooted, still doesn't work. I tried looking around for the suggested manual tag change in regedit but I can't seem to find it. Can anyone help me out?
Thanks for your help!
-DVD-Dude
Care to try a different version of DVD2AVI.
decodefix110.zip is a fixed DVD2AVI available at:
http://neuron2.net/fixd2v/decodefix.html -
you can use DVD2AVI to create a project and the will create the .wav
go to Audio/Output Method/Decode to WAV(AC3,LPCM)
go to File/Save Project [F4]
this will create the .wav and a .d2v file which you can load into TMPGenc and encode an .mpg
make sure you have a copy dvd2avi.vfp in tmpgenc folder so it will know what the .d2v file is.
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
Scratched disc - VOB ok but AVI out of sync
By Spoondog in forum DVD RippingReplies: 1Last Post: 3rd Nov 2009, 10:47 -
DV AVI to WAV problem, exports in Units? then no dvd SYNC
By mrmoodswing in forum Capturing and VCRReplies: 0Last Post: 20th Jul 2008, 17:35 -
How to convert .vob to .wav?
By showmi in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2008, 13:27 -
AVI - VOB = out of sync
By EliteMarine in forum Video ConversionReplies: 3Last Post: 22nd Dec 2007, 02:04
