Using Nero to convert .avi to DVD5. Stand alone player reports that disc cannot be played due to area (zone) restrictions. How can I burn to DVD with this Zone?
TIA
GG
zone restrictions
If you mean like a region code , they are only present in comercial pressed discs, Definitely not in an AVI and not put on by Nero.
Trying to use Nero to do everything from AVI to DVD-R is NOT the way to do things.
If you want to convert from AVI to DVD you want to learn how to do it properly.
You need to convert the AVI to Mpeg2
Then you need to 'Author ' the files
Then Burn them to a DVD-R
I suggest TMPGenc to convert
TMPGenc DVD Author to Author
And Nero to Burn.
IF you click on the TMPGenc names above they will lead you to guides on their use.
There is a lot more to this than a one click solution.
VB code to read DVD Control Data Zone
By casejustin80 in forum ProgrammingReplies: 0Last Post: 28th Mar 2009, 12:34 -
Can an ATSC tuner in an HDTV read a DVD zone 2?
By julax in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2009, 12:12 -
Question about zone burning rings on DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2008, 17:24 -
Free zone Citizen C201 DVD
By Pap in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Dec 2008, 01:00 -
Looking for a region free /zone free DVD Recorder. Questions about the zone
By perdue27 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 10th Mar 2008, 15:09
