i have tried the download link from the tools menu but it doesn't seem like it's up.
basically, the only new feature i want is the play all menu item. do you think i might experience any other problems making dvds as usual just to add the play all button.
web site is down -- try again later
http://www.mediachance.com/dvdlab/dvdlabpro.html"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yeah i tried doing that before, i burned a bunch of bad dvd-rs the first few times getting it right. it's hard work and takes about 10 minutes. i'm making a bunch of multi episode discs and want to try using dvdlab pro.Originally Posted by reboot
lot of bugs still in the pro version ... more for experimenting at this point
i'm sure they will all be worked out -- but it IS beta still"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yes!! the site is back up. dvdlab pro is awesome. especially the playlists and multiple VTS files.'
also, do you know if the pro version beta version does expire in 30 days since it is unavailable to purchase yet?
DVDLab Pro ugly text
By optikon2222 in forum Authoring (DVD)Replies: 1Last Post: 14th Oct 2010, 15:26 -
DVDlab pro eating some legends
By bebado22 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 16:54 -
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 19:04 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 08:28
