I'm ripping with decrypter and tried burning 2 disks and 1 with dvdcopy, but won't play on computer or pioneer dv333. So now tring dvdcopy to hd folder and burn at 2x speed with nero (I got new Taiyo Yuden 4x media suppose to be good quality and pioneer 106 burner). Previous tdk 2x were fine with dvd2one (usually movie only)
How often does 2x vs 4x dvdr make a difference in standalone playability, and if so, any difference in dvd2one vs dvdcopy in either making movie only or squeezing to one disk or spliting to 2 disks, in terms of quality or playability?) Is there recoding when 'movie only' option in either program choosen if its less than 4.34 gig?
Jack
Originally Posted by jayjay139
I don't know about quality between the two but try using DVDShrink and you may find that gives you satisfactory results and maybe even better playback
Again if you want movie only option just use DVDShrink and it will rip the movie direct from the DVD
Free Way to create RM files???
By John Kurtzke in forum Video ConversionReplies: 9Last Post: 20th Dec 2010, 22:15 -
Best way to create HD files ?
By pmugghc in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2010, 20:28 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
how do i create ifo etc files
By gurunutkins in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2007, 11:41 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
