Hello,
I have just converted a DIVX file to MPEG2 using TMPGEnc
I then exracted the audio from the DIVX to a wav file using Gold Wave, then converted the wav file to AC3 using besweet.
So now i have a video and audio file![]()
The video file is 4.30Gb
The audio file is 271Mb
When i use TMPGEnc DVD Author to make the DVD it says theres not enough room on the disk, i am using 4.7Gb DVD-R disks.
How can i make it fit ?
Cheers
Results 1 to 9 of 9
gsvgaming.net sponsored by 4u-servers
a 4.7GBb DVD doesn't hold 4.7 GB of data, only holds something like 4.33 so you need to reduce the size of your video, audio, or both
Hunting, sure i'll go hunting. When is cow season? -
I have encode the AC3 at 192 bitrate, that makes a 203Mb file.
Still to big
How can i reduce the size of the video ?
Cheersgsvgaming.net sponsored by 4u-servers -
Finish it off with TMPGnc DVD Author then shove it through DVD Shrink, then burn to disc. Easy
DVD-R is 4.38Gb
Should fit.The video file is 4.30Gb
Doesn't 4.30Gb + 271Mb = 4.57GB?DVD-R is 4.38Gb
Should fit.Hunting, sure i'll go hunting. When is cow season? -
As steveryan said author your video and audio in TMPGenc DVD Author , it will probably give you a warning about nonstandard DVD or something like that , click ignore or continue antway and complete the authoring stage.
Then open your VIDEO_TS folder in DVD Shrink and let it shrink the folder to fit a DVD-R.
It wouldn't matter if your video was 2GB oversize it would work fine that way.
The reason you had a 4.3GB video + you audio in the first place is that you didn;t calculate your video bitrate correctly in the first place. Have a look at this guide to see how to do it correctly.
https://www.videohelp.com/forum/userguides/186739.php -
Doh - Homer moment. WTF was i using for a calculator?!
Yeah - SHRINK it. -
Maybe not a Homer moment...you just had your head up your shiny metal ass.Originally Posted by holistic
j/k
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
dvd way too big?
By item9 in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2009, 00:41 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51
