is there a good tool or plugin to remaster the sound on a compressed realaudio file? they always have those nasty compression artifacts, and I wonder if there's a recipe how to reduce these.
not without the source material.
it's like trying to turn the turd back into the pizza.
can i say turd? is that allowed?
dlv -
are you sure? I mean I guess you can at least make it sound a bit better, cause for example the higher frequencies sound more damaged than the low ones...
you can try messing with the EQ but most likely it will just increase the "warbling" sounds...
RealPlayer Downloader
By oicram in forum MacReplies: 0Last Post: 15th Oct 2011, 11:14 -
Using RealPlayer on XP vs Win 7
By solarblast in forum Software PlayingReplies: 5Last Post: 10th Jun 2011, 08:06 -
No audio in WMP 11 or RealPlayer
By jameshgross in forum Newbie / General discussionsReplies: 2Last Post: 12th Dec 2008, 01:06 -
Pb watching WMP / realplayer on TV
By siljan in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2008, 03:26 -
Time disparity with realplayer
By subsync in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2007, 12:48
