  1. ANOTHER SIMPLE STUPID QUESTION. DO YOU KNOW IF YOU HAVE TO ALWAYS FORMAT DVD-RW DISCS BEFORE YOU BURN ON THEM
  2. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    You mean erase the previous contents, then the answer is YES.
    I Have Always Been Here
    Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
  3. NO I mean format the disc before its used for the first time. a virgin so to speak
    Nov 2002
    Poplar, WI
    If you are going to use the disk for DLA (drive letter access) which allows you to drag and drop files in explorer, then yes. Otherwise no.
    You create your own reality. Interested in media servers and HTPC? Can we talk?
    Apr 2003
    Largo, FL
    I don't know about all burn software, but with what I've used- if the disk is formatted for DLA and you're going to use it to burn non-DLA you also have to erase the disk (not just delete the files on the disk).
