i have an avi and want to convert using mainconcept.....worked fine but half way through the video clip the picture freezes but the sound carrys on.what can be causing this?
Open the .AVI file in VirtualDub and scan for bad frames. Should it find any, this guide covers the correction you must perform:
https://www.videohelp.com/forum/userguides/142555.php
This may well cure your problem.
Best of luck,
Cobra -
i've scanned for bad frames and it sayin...276 frames masked(1 frames bad,275 frames good but undecodable)...what does this mean?
It means that the .AVI is damaged and a frame (picture) cannot be read by the encoder. I assume this causes the encoder to get confused and not read any further.
I think you're going to have to follow that guide and cut out your bad and undecodable frames. Here's a thread where a user has had a similar problem:
https://www.videohelp.com/forum/viewtopic.php?t=171394&highlight=frame+undecodable
Are there undecodable frames in parts before your freeze-up in MainConcept? If so, I don't think you'd need to remove them so that will save a bit of time.
Hope this helps,
Cobra -
I prefer to use this method on badframes:
1) Load the .AVI file into the most recent version of either VirtualDub or VirtualDubMod
2) Set "Video" to "Direct Stream Copy"
3) Select "Check for errors"
4) Select "Mask bad frames"
5) Save with a new filenameCheers, Jim
My DVDLab Guides -
Nice tip, dude! I'll have to try that one of these days.Originally Posted by reboot
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
