I have an AVI file that's about 400MB. I've tried converting it to an MPEG file so that I can make a VCD. I've done this with other AVIs without a hitch.
But I'm getting a big problem this time. Using TMPGEnc, it notifies me that that file size will be over 1G, or more than my CD can handle. Further, the process is taking forever - it looks like it could take 12 hours to finish!
I tried using Virtua Dub, but it also noted that finished file size will be huge.
I've never seen something like this before - it's almost like the AVI was super compressed, and converting the file somehow releases files. Is there something I can do to prevent the finished product from being appreciably larger than the original AVI file?
Thanks.
Results 1 to 10 of 10
Hi imrealdumb,
Use AVICodec to get a load of info on your AVI and post the results back to this thread. I've seen this before but can't quite remember what the cause was (I have my suspicions, but won't mention them just yet in case I send you on a wild goose chase...). I'm hoping that details of the file will jog my memory...
Failing that, someone else might know the answer from the info provided.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks, daamon.
Here's what the program says about my file:
File : 349 MB (349 MB), duration: 0:42:13, type: AVI, 1 audio stream(s), quality: 50 %
Video : 310 MB, 1029 Kbps, 23.976 fps, 608*336 (16:9), XVID = XVID Mpeg-4, Supported
Audio : 38 MB, 127 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
I'm trying to create a VCD straight with NERO and letting it do the encoding. It's working so far, but it's taking a long time.
Thanks. -
When you open the avi file with virtualdub does it give a warning about it containing VBR audio. If so thats why Tmpgenc doesn't like it. Extract the audio and convert it to uncompressed wav. Then use that as the audio source and the avi as the video source when you encode with TmpGenc.
EDIT: bugster, the mega-fast typer, beat me to it. At least the response was the same...
Aha - MP3! There's a good chance that it's VBR, and (I'm sure I remember this correctly), VBR audio upsets TMPGEnc and causes huge files etc.
To sort the audio:
1. Load the AVI into VirtualDub.
2. Under the "Audio" menu, select "Full Processing Mode".
3. Under the "File" menu, select the "Save as WAV..." option.
This gives you a WAV file that you can then use as your audio input with TMPGEnc. This should (may - disclaimer
) sort the problem.
I mention TMPGEnc coz it's real good at converting to MPEG for VCDs and is free. Give it a go....
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Bugster,Originally Posted by bugster
You're right. I neglected to mention the error I received with VirtuaDub.
Here's the error I got:
VBR audio stream detected
VirtuaDub has detected an improper VBG audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduced up to 6726 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 127.6 * 15.9 kbps)
I'll try stripping out the audio per the suggestions you and Daamon have laid out. Thanks. -
Ok, it's working fine with TMPGEnc. Thanks to both of you.
I notice, however, that it's going to take a LONG time (althought the finished product size will be manageable.)
I'm wondering if the video quality is too strong. Is it possible/a good idea to create a different video stream at a lower resolution or something (like how I made a separate audio file)? Would that allow the MPEG creation process to occur quicker?
Thanks. -
TmpGenc is slow. There are many threads on optimising the settings for the best compromise between quality and speed. You say you are converting it to VCD. This is probably the quickest format to convert to. Check you settings. Do not use any filters unless you really need to and set motion search precision to normal or motion estimate. Do not use the high setting and definatley not highest.
Or get a faster processor! -
Quick question,
I took the advice and used the original file for the video track, and the WAV I had created for the audio. It created an MPEG, and I was able to burn it into a VCD.
Only issue is that the audio track was off by a second or two. Is this normal when you use this technique? Any way of preventing it and/or manually syncing the video and audio tracks?
Thanks. -
Converting huge MP4 to AVI
By lilblu in forum Video ConversionReplies: 10Last Post: 19th Mar 2009, 06:54 -
Converting AVI file to mpeg 2 question.
By ingeborgdot in forum Video ConversionReplies: 17Last Post: 7th Nov 2008, 21:49 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 18:31 -
Converting MOD file to AVI or MPEG!!!
By OnelnAMiII25 in forum Video ConversionReplies: 10Last Post: 5th Mar 2008, 16:48 -
Converting or Compressing a HUGE Video File
By megjad in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jul 2007, 07:43
