Ok the original 512x384
29 frames a sec
148 kbs data rate
xvid
i am trying to figure out the best quality i can put onto a dvd with 4 or 5 eps, i am trying to make it 352x480, i made a movie, with 4000kbs and the movie is great except for the movie pulsating when the camera moves on still objects. Like when no one moves or is talking, the camera moves across them and the local building it pulsates alittle.
Any help would be great
Jeremiah
i am makeing dvds for NTSC
Closed Thread
Sounds like interlacing. That is the source is de-interlaced, and poorly. Does the original have this?
Did you encode it as interlaced or progressive? If interlaced, what field order did you use? You may have to reverse it.To Be, Or, Not To Be, That, Is The Gazorgan Plan
one topic is enough.
https://www.videohelp.com/forum/viewtopic.php?t=221888
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 10:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 23:19 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
