  1. hi,
    I have several concerts and one man show dvd's and on them the audio is on LPCM and AC3.
    99 times / 100 They don't need to be "shrinked" if I only keep the AC3 file.
    The problem is that by default the dvd start playing the LPCM track (0x80) and the AC3 track is 0x81.
    Is there a way to enable playing directly the ac3 audio instead of manually switching (or go to the dvd menu) to select the ac3 track ?
    Does ifo edit can do that (I didn't find the option) ???
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    yes, you can switch the default audio stream in IFO Edit.
    I can't remember how to do it off the top of my head - you have to open one of the PGC's and add a command.
    here is the website where I found out how to do it : IFO Edit for Dummies
    after you change the .ifo, you might want to open it in a software player and see if the correct audio stream comes up by default, before you burn the disc.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
