I have several VOB trailers that I want to add to my project. Once I edit my movie, where can I insert the trailers so that they are part of the movie? Do I have to do something that will allow me to add these files to my project. And does it depend on what software you are using (e.g Pinnacle studio, Ulead, Vegas, Adobe etc)
It definitely depends on the software. You want to split your file and insert the additional .VOB files where you split it. Then you need to save the edited file or author it. The software will determine if you can do all this with the same app or if you need several apps.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting .mpg-files to .vob-files ?
By stuckinsnow in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2008, 09:11 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
