Are there any New Zealanders viewing this forum who have successfully coverted VHS (PAL format) to DVD?
I have downloaded, printed and read many of the FAQ's and "How to" articles, but no matter what I do, everything turns to custard
A brick to the head may help
I'm using a WinFast TV 2000 XP Expert Tuner/Video card.
Describe your work process. At what point do your efforts fail? It's kind of hard to diagnose the problem when so little information is given.
Hey Zippity,
have you captured your VHS to your computer yet, do you have a mpg file ?
if so whats it look like -
Nero 6 has format selections for every TV style on the planet!! I use NTSC but there is a HUGE list of other types under it. If you have captured TV Nero will encode it for you.
I use it with a PIKA ONE 8X dual DVD. Brag: Just burnt a full DVD in under 12 minutes onto Datawrite Classec DVD+R 8X. See
www.datawrite.co.uk
They cost less than 68 pence each for 25 tubes here;
http://ukdvdr.co.uk/acatalog/DVD_R.html -
NZ TV uses NICAM for the HiFi Stereo, but apart from that NZ uses bog standard PAL. The only difference in a NZ VCR is that it supports receiving NICAM.
As you are outputting from the VHS tape, it is 100% bog standard PAL.
Follow the guides on this site. -
A) What platform
B) How much are you converting.
If you have a lot of media a stand alone DVD Recorder is probably best.
Otherwise you need a decent capture card, a hell of a lot of HD space and a lot of time.
I've personally been doing a lot of this under Linux quite easily, but it wouldn't suit the average windows user.
Capturing PAL S-VHS-C - Advice very much appreciated
By Genu29 in forum Capturing and VCRReplies: 2Last Post: 31st Jan 2012, 07:02 -
Capturing VHS - Advice appreciated
By sl74 in forum Capturing and VCRReplies: 5Last Post: 25th Jan 2012, 11:14 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
Help needed converting HD h.264 Freeview recordings (New Zealand)
By Chopmeister in forum Video ConversionReplies: 26Last Post: 25th Sep 2011, 02:18 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 02:09
