  1. Hi,
    I hope you guys can help me. I can not get my NEC 1100A to burn at 4x. I have read the related threads, still can't do it. I successfully flashed the firmware to v 1.90. I think the newer versions can do it. But I can not use v 1.91 or A3 they both say drive not found. I went to this site http://etna.rpc1.org/nec/ and follwed the instructions. First I couldn't make a boot disc as instructed that would fit on a floppy. Second I really don't know dos that well. Any help is really appreciated, I'm extremely frustrated. Thank you.
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    go to this site and read about NEC burners:
    http://www.herrie.org/
    also you can read information on your NEC & post your question at this site:
    http://forum.rpc1.org/index.php
  3. I guess this is too techical for me I was could find a firmware that I can run in XP not in dos that would solve this problem. I got the files to use in dos. Maybe if you could explain what this means, I could be in better shape.
    The config switches are:
    -pri (Primary) -sec (Secondary) -mas (Master) and -sla (Slave)
    First you can make a backup of your current Firmware:
    NEC1x00A.EXE -sec -sla -out original.bin (Enter)
    To flash choose:
    NEC1x00A.EXE -sec -sla -flash filename.bin
    (In the examples above I assumed you have your drive installed on your secondary IDE-controller as Slave)
    I tried using the MS dos prompt and got an error. I not sure hope exactly to imput the info? IS there a live shat anywhere that you can recommend to ask?
    THanks
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Post your questions on how to flash your drive at the sites I gave to you. I don't own a NEC drive. Every drive is flashed differently.
