Hi All!
I have an AVI file, encoded in Xvid. I have converted it in MPEG-2 (using TMPGEnc), and I saw that in the end, the sound and image were out of sync.
Looking the original AVI, I realized that it contains a (short) scrambled part. After that point, occurs the loss of sync.
The question is: how can I convert to MPEG-2, without losing the sync?![]()
Best regards,
Joelson. -
Cut the scrambled part out. Scan for bad frames. Hope for the best. Most times you got an aborted clusterfuck on your hands that ain't worth ******* with.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Originally Posted by sacajaweeda
sacajaweeda: THANK YOU for the hint!!! That was the solution!
teegee420: Thank you for the link to the guide!
It finally worked, thanks to your help!
Just a doubt: in the original AVI file, the scramble was already there, but the audio and video were in sync. How the lack of sync showed up only in the generated MPEG file?Best regards,
Joelson. -
The badframes you had would have caused the encoder to struggle past the video that was bad the audio would have carrried on encoding as normal , when the video stared encoding again it would have been delayed so the video was out of step to the audio.
Its always worth scanning for badframes before encoding any downloaded AVI file , If you have bad frames right near the end you could spend 3 hours encoding and have to start again , it's definately worth spending 15 mins to make sure your file is ok first.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 12:30 -
Searching for analog scramble channel video effect
By Starkian in forum EditingReplies: 4Last Post: 7th Oct 2008, 07:32 -
video goes out of sync
By scottygelbs in forum Newbie / General discussionsReplies: 8Last Post: 25th Dec 2007, 20:19
