Hi all,
I wrote a very simple Linux command line utility to convert MPEG2 files from a TiVo into DivX. It's mostly a very tight Bash shell script with a little bit of C thrown in. Give it a try if you have need of such a thing!
Homepage:
Features:
- very high quality 2-pass Variable Bitrate Encoding (VBR)
- ability to specify output filesize _or_ bitrate
- audio is directly copied without re-encoding, for optimal quality and to maintain perfect sychronization between the audio and video streams
- output scaled to the correct 4:3 aspect ratio, with several options for output size
- very good de-interlacing filter
Requirements:
PS: Check out Philips DVP642 player. Ultra-cheap, progressive, plays DivX and everything else I have thrown at it. $70 at compusa.
Results 1 to 1 of 1
Babylon 5 Re-release on DVD5 ?
By Noahtuck in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2012, 16:48 -
Simple DVD editing and encoding software? (Scene release)
By djkilla in forum Authoring (DVD)Replies: 4Last Post: 18th Nov 2011, 08:48 -
Hardware / Software for cinema release
By andrewgerm in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2009, 02:29 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
Did I release a virus on my PC?
By mn072065 in forum ComputerReplies: 11Last Post: 18th Aug 2008, 17:33
