Closed Thread
  1. Hi everybody! I have downloaded The GodFather III from emule and when I unzip there are several files in the resultant folder:
    video_ts.bup
    video_ts.ifo
    video_ts.vob
    vts_01_0.bup
    vts_01_0.ifo
    vts_01_0.vob
    vts_01_1.vob
    vts_02_0.bup
    vts_02_0.ifo
    vts_02_0.vob
    vts_02_1.vob
    vts_02_2.vob
    vts_02_3.vob
    vts_02_4.vob
    vts_02_5.vob
    The thing is that when I try to burn with nero it says:
    DVD-Video files reallocation failed. The resulting video might be unplayable. Do you want to continue?
    What can I do to fix this? Thanks a lot everybody
    Feb 2004
    WI.
    Don't download movies! Buy them. Then read the forum rules!
  3. Originally Posted by Lamberth
    Apart form the correct responce above...
    At least you admitted WAREZ you got it from...
    Just burn it....9 times out of 10 it will play OK.
    Not bothered by small problems...
    Spend a night alone with a mosquito
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Not the sharpest tool in the shed, are we ????
    What part of this do you not understand ???
    If in doubt, Google it.
    The error means some files are corrupted.
    Buy the DVD. It's in stores !!!
  6. As per above, this comes under warez and as such isn't allowed on this site.
