I have tried this codec and got it to work once, but have forgotten how. I know i added a few dll files to get it to work, but can't remember what they were or where i got them from. I know it wasn't the regular vb6 package, it was (I think) 2 individual dlls. Does anybody know how to get it to work?
Thanks!
Rog
There should be a .inf file. Right click it and select "install".
To make sure we are talking about the same thing, are these the files in the archive:
DVDAudio.ax
DVDVideo.ax
README.TXT
regfilters.bat -
I've never been able to get it to work on any PC I've installed it on. I just install the trial of Power DVD and then uninstall it. That leaves a good fully functional MPEG2 Codec on the system.
hmm still no luck. i've tried uninstalling dangnear everything and it still gives me a screwed up picture. There does not seem to be an .inf file with it, it
is just an .exe file. Will keep trying.
Thanks!
Rog -
Installing Power DVD is probably a better idea. Or you can install the K-lite Codec Pack, which installs either the Ligos or Elecard mpeg-2 decoders. Make sure you choose a custom install and only install what you need. You're looking for trouble it you install everything.
Hey thanks. Got the K-lite package and it works fine now. Is ligos a free mpeg2 codec? I never see it offered by itself. And it took me a while to figure out the girl is from Kill Bill I. Thanks!
Rog -
I'm pretty sure the Ligos version in the K-lite pack is free. I've had it for a long time and no nag screen yet. Good job for recognizing Go Go.
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 01:35 -
proprietary codec used by Sharp for MPEG2
By ghostma in forum Software PlayingReplies: 17Last Post: 16th Nov 2011, 18:11 -
no sound on some movies when playing with ps3 and mpeg2 codec issue
By dhyane in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2010, 10:18 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 02:49 -
It was a stinky situation...
By zzyzzx in forum Off topicReplies: 3Last Post: 18th Jan 2008, 15:27
