Anyone else have a problem with DVD Decrypter when following the guide on this site for extracting AC3 files? On two computers of mine, when I attempt to rip the selected file to an AC3 file, DVD Decrypter creates a .VOB file instead of a .AC3 file. If I simply futz with it, not actually changing any settings but toggling them, eventually, it will create the .AC3 file. Bizarre. Anyone have the same problem? Again, this happens with two different PC's on multiple DVD's, following the steps in the guide on this site for extracting AC3 files from DVD's.
I've done it before but rarely do I need JUST the AC-3 audio.
So my normal proceedure is to rip in FILE mode then run the VOB files through DVD2AVI
This will create a D2V project file for using the video as well as spitting out the AC-3 and DTS audio tracks.
Works very well and doesn't take much time (i.e., DVD2AVI).
ifo mode,
select stream, then click on demux box. repeat for all streams of interest.
An AC3 stream with the delay noted in the filename is created for you.
Same process for demuxung the video stream,
etc.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Originally Posted by awlchu
If this was just one PC, or one DVD that this happened on, I'd write it off. But two PC's? Weird. Think I'll try what John Coleman suggests instead... -
You should let UK Lightning know (dvddecrypter author) about this problem.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 17:55 -
AC3 Sync problem out of MKV file
By betão in forum Blu-ray RippingReplies: 7Last Post: 9th Jul 2010, 22:30 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 03:38 -
DVD Decrypter Problem
By WuPhilly in forum Newbie / General discussionsReplies: 14Last Post: 17th May 2008, 16:28
