I have an AVI with a 780K/Bit quality. What I would like to do is take that AVI and reduce the quality to a bitrate of about 350K/bit quality to use on a Pocket PC. ANyone know how to reduce the bitrate of an AVI. THanks in advance.
Virtualdub, with (just a suggestion) XviD, or DivX mpeg lowmotion codec.
Cheers, Jim
My DVDLab Guides -
WHat is the best way to do it in Virtualdub? I have that so I should be able to do it with the right advice.
I will try and extract audio to a wav file. Then process the video and reduce the bitrate and merge the wav file. Is this the right way? -
If you don't want to modify the audio stream then I would use Virtualdubmod and just set it to "fast recompress." Then setup either Divx or Xvid with a video bitrate of 350 for both passes.
If you want more info on PPC video playback in general, then checkout the forums at this site.
-Suntan -
There is no need to demux the avi into separate streams.
Fast recompress is one easy way to do it.
Either way, virtualdub(mod) is the tool you need.
You could just leave audio intact, and simply re-encode the whole thing to whatever spec you need.Cheers, Jim
My DVDLab Guides -
A simple way to do this is with Window's MovieMaker2. It's free and it comes with WindowsXP You can convert the AVI to a *wmv which should be viewable on a pocket PC
This is so much fun!
Seeking expert advice - Mkv to AVI + Subs (Mencoder)
By izzy2k in forum Video ConversionReplies: 2Last Post: 7th Apr 2009, 10:28 -
who is here from uk and is a ripping expert
By lóreal in forum Off topicReplies: 7Last Post: 21st Mar 2008, 20:23 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 13:45 -
Please! An expert for codecs...
By xtrips in forum Media Center PC / MediaCentersReplies: 3Last Post: 21st Jul 2007, 00:38 -
Need an expert advise on converting AVI (or SWF) to MPG High quality video
By oavs in forum Video ConversionReplies: 10Last Post: 10th Jul 2007, 15:41
