Results 1 to 13 of 13
  1. Please help me, I want to cut in 2 one *.VOB file and I don`t know what program to use. This
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    You could try Womble MPEG VCR.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Womble will output an mpeg, in case that's a problem.....
  4. Thank you very much, the problem is that this VOB file contains 4 sound track in different languages, and i don`t want to lose any of them. Do you know a simple cutter for this operation ? This VOB file is 1Gb large and i want to cut it in 2 equal parts. Is it possible to appear delays on some audio tracks in the second half ? Thank you again !
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    This may be a silly question, but why do you want to split the file if it is only 1GB ?
  6. I want to store them on 2 normal cd`s. The original file is ~1,1 Gb. Split in 2 parts should fit on 2 cd`s at 650 Mb. Thank you again.
    Bromley, UK
    try ...
    http://www.doom9.org/index.html?/software2.htm
    and then go to Vob tools - this has a direct VOB cutter and splitter ....
  8. If you just want those files as files, you can use a great little program, which can spilt ALL kind of files into whatever size you like, it is called HJSplit get it at
    www.freebyte.com/hjsplit/
    I believ it was made for storing things on floppydisks, and email applications, but i use it for all kinds of things. there is also a linux version out
  9. Thank you. You are a funny guy. But if you had a little movie would you like to keep it stored on a CD in a format that does`nt permit you to play it directly, but only after you copy both CD`s in the HDD (need >1 Gb) recreate the hole file (another >1Gb) so after a few minutes you could play the little movie... I also ure WINRAR to do the think you do, you can set the files size to any value and compression ("store" for maximum speed) and it`s a huge advantage:anybody can reunite the files because everybody has a WINRAR in it`s computer.
  10. Member teegee420's Avatar
    Dec 2003
    Southern California
    Not exactly. Windows XP can handle zip files but not rars. One would have to download WinRAR.
  11. It`s O.K. at last.
    Thanks to TEEGEE 420 !
    Thanks to ZIPPY P !
    My english is not enough good to help me as i wish.
    Probably i would had rezolved my prolem a few days ago, but i had a problem with my download. It`s not easy for me to read hundreds of pages on this forum...
    On the other hand i discovered that the last version of WINZIP can also split files like WINRAR did years ago. Anyway, that was a way out of question.
    Anyway EVRICA !
    I discovered America !
    I had just downloaded those:
    -Mpeg2Schnitt06i
    -vobspl26
    -Vobedit06
    -MPEG2Cut-1.15
    -dvtool024
    One of these, from this assome site, should work for me.
    Bye !
  12. Thank you TEEE-REX.
    You`re the best.
  13. i use MPEG2Cut-1.15
    just work find
    To be more specific.
