  1. Hi,
    I'm testing DVD2OneX but i've a problem and i would know if it's a known bug or if it's related to my own configuration.
    Say, my VIDEO_TS directory is /Volumes/Vrac/DVD/VIDEO_TS : if i try to use the '...' button to choose it, i can select it but the source text field says only /Volumes/Vrac
    I have to complete it manually and, then, it works. Seems strange though.
    Any clue?
    Jun 2001
    Silver Spring, MD USA
    Trash your plist preferences file for this app then restart the app. That might fix it.
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    would it process it anyway? it could just be a "cosmetic" issue.
  4. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Are you selecting the actual VIDEO_TS folder and hitting the 'choose' button? Make sure you select the folder. If that's not working, are you perchance using a <cough> borrowed </cough> serial number? People have reported this issue with illegitimate serials. If that's the problem, you might just live with it, or purchase the app.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
