  1. What is the easiest/best/fastest way to find out if a burned dvd is PAL or NTSC?
    Is there some kind of program that will give you that info as soon as you put it in your dvd drive ?
    Thanks,
    papaholmz
    Dec 2002
    How can you make a DVD if you don't know the format? I know how, shame on you.
    Most software players will tell you the resolution and framerate. 25 fps is PAL. ???x576 and ???x288 is also PAL.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. Or drag anyone of the vob files into bitrate viewer and check the fps and resolution of the mpeg in there.
