I am trying to create a video clip for a menu on a DVD I am authoring. I would like to have it play a short video clip with music in the background. The problem is that the length of the video I want is much shorter than the length of the audio, so what I would like to do is have it play the video clip and stop on the last frame of it while the audio is still playing. What is the best way to accomplish this? I was thinking I could just encode a still of the last frame to make it take the difference in time between the length of the audio and the original video and then join it to the original video clip then multiplex it with the audio and I'll be all set. Is this what I should do? What tools should I use? Also, I am using TmpgEnc DVD Author to author. What will happen if I use this clip for the menu? Will it play the whole thing once and stop, or will it start over once the music/video finish?
Results 1 to 1 of 1
creating a dvd menu
By petarone in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2010, 13:29 -
Creating A DVD Menu
By 557953 in forum Authoring (DVD)Replies: 8Last Post: 19th Jun 2008, 09:41 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 20:42 -
After creating a video CD I only get the menu to appear...help
By dave4500 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jun 2007, 02:23
