I am completley new to DV, and was wondering is it possible to capture DV from TV and if so how and is it really good quality
If your camera has pass through, you can plug in your TV's output into your camera and on to your computer's fire wire card.
If your TV does not have video out, then your have to have your VCR provide the video output.Hello. -
The answer is as posted above,... if you have a Digital Camcorder with Pass through,... you can convert just about anything to DV. I have Direct TV with S-video output and my Camcorder has S-video input and firewire output to my PC. I can capture (transfer) high quality TV signals of any program on Direct TV, or even good quality Digital signals on Cable to my PC. Then I edit out the commercials and make a DVD. I also just "VCR Tape" the program and then feed it to my PC when I get the time. The quality is as good as the orginal Signal,... that is if you have a good VCR. Anyway, when I play back the produced DVD to my TV, I can't see any difference in the quality from the original broadcast.
Remember,... it will never be as good as a DVD that you buy or rent. IF you want the best, then rent the DVD and rip it and make your own copy.
It all starts with the Digital Camcorder,.. and a good Non-Linear Editing program. I use Ulead VideoStudio 7.0"Technology",...It's what keeps us all moving forward. -
Bstansbury
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
