After ripping my Vob files to my hard/d I tend to use powerdvd to open them to see which one is the english audio file so I can tick the right audio decoding number in dvd2avi. Example In powerdvd you can see audio 1 =english 2 = german 3=spanish and if the 4th one is again english I tend to presume that it is the directors comments all the way through the film so I choose number 1 then i have both my audio and video files for tmpgEnc. But this time the 1st vob has a 2 min preview of the film just before the film starts like a trailer. But the no 1 audio is english ( the Film ) and 2 german 3 spanish but 4 is the preview so i need 2 audio files first 4 and then 1.therefore I have to tick 1 and 4 in dvd2avi. how do I do this, can i just join the audio files with any audio program, or will the film be out of sync ? Thanks in advance
<font size=-1>[ This Message was edited by: PcJockey on 2001-11-10 06:40:59 ]</font>
<font size=-1>[ This Message was edited by: PcJockey on 2001-11-10 08:09:23 ]</font>
what ripper are you using? is it capable of stream processing(parse .ifo)? if you can rip the intro & movie seperately or by chapter your problem is solved
im using claddvd and the preview is embeded in the first vob never seen that before. what ripper can rip by chapter
<font size=-1>[ This Message was edited by: PcJockey on 2001-11-10 16:02:28 ]</font> -
stanwebber is correct u need can do stream processing and rip the movie sepately from the intro....if u dont already use it go get smartripper..it is the only ripper that can do all the things we suggest
what hope do i have if i already took the dvd back and only have the vob files on H/D
do u have an ifo file..if u do use DVDx to encode it uses the ifo file to encode the movie and u can select the movie or the intro to encode...but it wont have the great quality with TMPGEnc but it is still a good quality encoder..atleast u have the movie rite
Selecting passthru audio in MPC HC rather than the prologic
By skinney6 in forum AudioReplies: 2Last Post: 26th Jan 2012, 11:37 -
Selecting audio/sub tracks when streaming to PS3
By Ronin Silfar in forum Software PlayingReplies: 2Last Post: 29th Jan 2010, 03:48 -
From DV camcorder to DVD with Nero. helpppp
By kscott0986 in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2009, 09:17 -
selecting audio track
By july in forum AudioReplies: 0Last Post: 9th Jan 2009, 15:13 -
Selecting audio input in wavelab
By jcoops16 in forum AudioReplies: 0Last Post: 2nd Aug 2007, 15:53
