I recorded some Game footage using Fraps 2.1x (registered) which generates Uncompressed AVI files.
GSpot was having a tough time telling me what CODEC I need to play them. On one computer, they play fine. But on this one, they won't. I hear audio, but no video.
I'm not sure which codec I need to playback uncompressed AVI files.
Any tips/help?
Results 1 to 10 of 10
Did you try rendering it in G-spot? Virtualdub might be able to tell you what 4cc it uses. Go to file>file information. By the way, cool avatar.
DirectShow partially succeeded to play file. The actual text of the error or warning is: 0x00040242: VFW_S_PARTIAL_RENDER - Some of the streams in this movie are in an unsupported format. The following combination of filters were used: {C:\Temp\game 2004-05-16 19-48-21-15.avi} (Audio Source) {AVI Splitter} (Audio Splitter) {Default DirectSound Device} (Audio Renderer)
GSpot was unable to find a suitable codec installed, indicating that this media file not likely playable on this O/S at this time. To be able to play this media file, attempt to locate a suitable codec based on the Format and 4CC given above. Install the codec and then test again with GSpot after the codec has been installed.
But what's wierd is that it will play on my other 2 computers. This computer is actually my Digital Video system, so this is baffling.
It's umcompressed AVI made by Fraps (http://www.fraps.com). -
Yeah; and I can't even get Virtual Dub to open it.
The file(s) are fine. My other PC can open them up across the network. -
Sorry if this is a dumb question but you have Fraps installed on the computer in question, right?
How embarassing, yet so very simple.
Being an uncompressed AVI stream, I didn't realize I would need to have that program installed; nor did I even think to assume that it installed a video codec.
THANK YOU ALL!! -
Originally Posted by Tolwyn
Oh, I know.
A 2 minute AVI created with fraps is over 700MB.
So, yeah. I didn't think that ANY compressing was going on!! -
Believe it or not, there was. I decompressed a 512x384 one minute clip and it was 829mb.
interesting security problem, need some input
By deadrats in forum ComputerReplies: 3Last Post: 23rd Nov 2009, 22:58 -
Interesting Connection Problem. LG DVD Recorder to Samsung LCD TV
By kramsey999 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Oct 2008, 01:13 -
An Interesting Problem
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 9th Jun 2008, 19:15 -
interesting VEGAS 8 render problem
By compusic in forum EditingReplies: 3Last Post: 8th Mar 2008, 08:11 -
Interesting problem with new Sony titles
By Nilfennasion in forum Newbie / General discussionsReplies: 8Last Post: 25th Aug 2007, 08:01
