hey guys, what is the best software for creating slideshow
why?
hacking the Net using typewriter :D
I use Ulead DVD Picture Show
I find it easy to use , I like the transitions and its easy to add music and title screens with text.
It just does every thing I need with ease. -
If just making a slide show...I use Slide Show Movie Maker...fairly straightforward, and pretty good transitions effects. Plus, adding music tracks is easy... Main drawback: it only saves the slide show in AVI format...but that's easily converted to MPEG using TMPGEnc
Why? IT'S FREE!!! -
Memories on TV is another - I happen to like it but haven't done a comparison against the others.. it's pretty easy to use and does nice transitions, encodes and authors and can burn, or you can take the encoded streams and use your own authoring / burning if you like
also, on the 'why', the adjustment of slides to song length is good and the panning / croping control, esp. w/ the new version, is very good"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
Creating a slideshow with slides at specific points in the audio
By Kiwi999 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2012, 01:18 -
Creating AVCHD slideshow
By chrisnewton in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 10th Dec 2010, 12:04 -
Creating flash/mpg/etc slideshow with text from file
By RandallM in forum Newbie / General discussionsReplies: 0Last Post: 12th Nov 2010, 13:50 -
Creating a slideshow as a standalone .swf file
By marioval in forum Newbie / General discussionsReplies: 8Last Post: 2nd Sep 2009, 12:36 -
Slideshow software ?
By Mike99 in forum Authoring (DVD)Replies: 5Last Post: 4th Nov 2008, 14:38
