i think i found something...
ok, the dvd i created is nearly perfect now !
i tested it in 2 dvd players; 1 rca and 1 jvc
it played correctly without the problems i encounter with the xbox...
what i don't understand is that on the xbox, i tried 3 different softwares and all 3 were producing the overlapping frames or blurry images...
so now i know i have 2 choices:
a) buy another standalone dvd player
b) re-encode the files...
I choose the option B)
but i need some help...
Could someone just point me to the best way to convert my dvb 704x480 files to 720x480 truly DVD compatible files...
i tried TmpgEnc and it gives me this error when i try to load the file ;
"file ... can not open, or unsupported"
so whats the best software and method... thanks.
704 x 480 / 576 is an official DVD framesize.
in short terms, DVD specifications support 720/704/352 x 480 "resolutions", also 352 x 240.
So it seems that your X Box isn't 100% combatible with the DVD specifications.
Anyway, you need to re - encode. So, you need to frameserve your mpeg 2 file with dvd2avi.
Read how to frameserve mpeg 2 on the Sefy guides at your left of this screen.
Also, I move this post to the DVB / HDTV forum.
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 06:38 -
DVB-T (.TS) to DVD conversion
By midders in forum Authoring (DVD)Replies: 10Last Post: 5th Nov 2008, 20:06 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 08:02 -
DVB to DVD with subtitles and chapters
By havema-1 in forum MacReplies: 1Last Post: 12th Aug 2007, 09:40 -
DVB->DVD-R->XviD
By drrat in forum DVB / IPTVReplies: 2Last Post: 11th Jun 2007, 07:02
