First of all I don't know wether this is the rigth place to post this, but anyway:
I want to create a DVD using different angles during the movie.
I have two static angles (left and right side) but the question is:
What is the best way of putting them together??
- This is a war and we are soldier, but what if tommorow the war could be over? Isn't that worth fighting for? Isn't that worth dying for ? -
I assume you are talking about the multi-angle feature in the DVD spec. My understanding is that it is similar to having multiple audio tracks, and you switch between them as required. To do this, you need high-end (read expensive) authoring software that supports multi-angle authoring. I suggest you look through the tools list, or ask in the DVD Authoring forum.
Ripping with angles
By Dozza in forum DVD RippingReplies: 4Last Post: 18th Apr 2019, 15:54 -
adjust angles
By ecos in forum EditingReplies: 2Last Post: 31st Jan 2012, 18:00 -
Angles using freeware - is it possible?
By Qun Mang in forum Authoring (DVD)Replies: 10Last Post: 5th Sep 2007, 09:27 -
Ripping DVDs with alternate angles
By Jeikobu in forum MacReplies: 0Last Post: 26th Aug 2007, 19:25 -
AutoGK mishandling angles
By briansmccabe in forum Video ConversionReplies: 7Last Post: 12th Jun 2007, 10:13
