I cannot seem to create any decent quality VCD's when I use Dazzle Video Creator II to capture footage from my Sony Digital Camcorder and then burn a VCD of those clips using Nero. I can however create pretty decent quality VCD's when capturing directly to Dazzle Video Creator II from my DVD player(music DVD videos for example) and then burn a decent VCD using Nero(Don't have to use TMPGEnc since Dazzle encodes it directly.)
I have spoken to the folks at Dazzle and have not gotten any earth shattering advice(after being on lifetime hold with their technical support). My question here is : Am I better off just capturing in AVI from my Digital Cam into a regular fire wire card( I Link 1394 Card) edit the footage with the accompanying software(Adaptec firewire Card comes with MGI Video Wave) and then encode it with TMPGEnc before burning with Nero. Any advice would be much appreciated. As you can tell I am not a VCD techie and am still learning the basics.
I have a problem with my software program(DVCII)not opening. I keep getting an error message that my OBDC Drivers for Microsoft Access will not load. The message also says that Microsoft Access Driver is out of memory. Has anybody had a similar experience
Note please diregard my posted message about the problem with the OBDC Drivers and the DVC II software not opening. I solved that problem long ago and apparently it was inadvertently published with my last message. I am however still seeking advice on my problems with creating a decent VCD by capturing footage into my PC from my Digiatl Camcorder. (Hey its either this or go back to my other life in fantasy football. Of course I could spend more quality time with my wife but these hobbies keep me out of trouble.)
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
Which miniDV or Digital 8 cam has the best TBC for transfering videos?
By theaveng in forum Capturing and VCRReplies: 12Last Post: 16th May 2009, 01:03 -
Pinnacle 9 - JVC cam problems
By Maarten in forum Capturing and VCRReplies: 3Last Post: 19th Jan 2009, 16:38 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 16:08 -
How to convert Digital Cam AVI to Xvid or Divx?
By Newbie_here in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 01:48
