When I try to import mpegs, I get the message 'Unsuportted [..]'
When I use Quicktime, I get no sound...
Any idea what I am doing wrong?
You're probably doing nothing wrong. Quicktime doesn't play AC3 audio without a codec installed. Try VLC or MPlayer instead to test it out.Originally Posted by Daij-Djan
As for DVDSP, try demuxing and remuxing the mpeg before importing. If that doesn't work, try fixing the time code with MoreMissingMPEGTools' BTS function. -
dsp only works with elementary streams (demuxed streams) use moremissingtools to demux and then change the audio to 48 if its not already.
pants on, pants off, pants the floor. -
What codec is this? I thought I found one but it doesnt work as expected.Originally Posted by pixeljammedia
Yes, thats the one ... I installed it without also installing DivX (I dont want it). Anyway, back to topic.
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Studio 14 Crashes when I import HD video.
By FinalGypsy in forum EditingReplies: 2Last Post: 16th Feb 2010, 14:26 -
Newbie wanting help? Import DVD/MPEG in Ulead VideoStudio
By Mark75 in forum EditingReplies: 4Last Post: 30th Oct 2008, 17:52 -
DVD Studio Pro will not import m2v files!
By CLE in forum MacReplies: 5Last Post: 20th Jan 2008, 18:14 -
How to Import MPG into Studio 9
By ozab in forum EditingReplies: 1Last Post: 30th Nov 2007, 19:11
