Greetings:
I just purchase a Chinese movie DVD in a store. Even though it indicated on the outside of the case that it's NTSC format, I can't play it on my Standalone DVD player. One player (Pioneer) shows a jumping black & white images while the other (Sony) displays a message that I should check the TV format. When I put DVD on my computer it plays normally and show that it's in PAL format. I did return to the store for an exchange; unfortunately, this movie doesn't exist in NTSC. The movies is an oldy which I would like to keep in my collection it if there is an easy way convert a PAL to a NTSC system.
Any input and advice is greatly appreciated.
Take a look see at this here other thread on doing PAL DVD to NTSC DVD conversions:
https://www.videohelp.com/forum/viewtopic.php?t=219852
Good Luck
Thanks for the great link.
I was hoping that there are an easier / quicker (sort of one click solution) way and less complicated for a DVD dummy like myself.
Effectively, I was reading your post and it sound all greek to me and w/o mentionning time consuming process. I keep it as a reference anyway. May be one day, I can play with it when I have spare time. -
Well you can buy a DVD player that will play back a PAL DVD and convert it to NTSC format for viewing on a NTSC only TV
Some models are better than other models with pricing ranging from dirt cheap to very expensive.
I have a Cyberhome CH-DVD 500 and it works great for this and can be bought direct from the cyberhome website for $79.95 plus S&H
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
An easy way from NTSC and Pal to DVD ???
By Dash1 in forum Video ConversionReplies: 17Last Post: 11th Mar 2008, 09:27 -
convert pal dvd to ntsc, but different
By atomicrabbit in forum EditingReplies: 5Last Post: 12th Jan 2008, 04:48 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 21:35 -
Easy way to play PAL DVD on NTSC hardware
By silverwolf0 in forum Newbie / General discussionsReplies: 10Last Post: 15th Jun 2007, 02:03
