Hi guys.. i´ve captured an old VHS to DVD using VirtualDUB then TMPGEnc (720x480 RGB24 M-JPEG HQ and Audio 48hz PCM + De-interlace / Noise Reduction / Crop)...
The video i got was great, but the sound of the VHS were bad, "not clear"...
Here in my PC i got Sound Forge 6 and Nero 6 Wave Editor ()...
I want to know what program/filter should i use to make the sound better, more clear (or at least try to do that)...
Thx for any help, and sorry 4 the bad english... 8)
the first thing you will want to do is a simple noise reduction. I have only used Adobe Audition so thats what I'll go off of. I tell audition to get audio from a video and it sucks the audio out of the mpeg file. Then select a part thats supposed to be silent, run the noise reduction filter and choose "get profile from selection". Then select the entire track and reduce the noise to a level that you are satisfied with. Sometimes doing 100% reduction gives you an "underwater" effect. Once you get it how you want it then I would look to a little fine tuning with the graphic equalizer..you can make it sound a little "clearer" by boosting the midrange or higher frequencies..its really a matter of playing around with peices and previewing untill you get it sounding how you want. Once you have edited the sound file then you re-add it during authoring.
hope this helps!
dlv
How can I make a .dts from wav's ?
By Robertus in forum AudioReplies: 2Last Post: 5th Jul 2010, 16:20 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
Audio Not Clear in AVI
By abdul_sma in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 10:59 -
16bit Audio not Clear :(
By ozab in forum Capturing and VCRReplies: 0Last Post: 31st Jul 2007, 11:51
