I'm trying to convert Quicktime to MPEG2
I have TMPGenc 2.5 ...
...tried to use the QT plugin from http://www.geocities.com/SiliconValley/4942/svcd.html
...it doesn't work.
Anyone know of another way to do it?
If you look at the comments in the tools section for this plugin, one guy says it works with TMPGenc 2.5 the other guy says it doesn't work.
(The quicktime clips came from my Canon A60 Still camera which takes short quicktime video clips )
Patrick
Results 1 to 9 of 9
Try Canopus Procoder or Mainconcept MPEG Encoder. Make sure you have a current installation of Quicktime too.
Don't have either one and didn't want to pay $60 for a simple task like this. Any other ideas ? Thanks for the post, though.
Patrick
Originally Posted by teegee420 -
The freeware utility Rad Video Tools can convert from Quicktime to AVI.
You'll find it here http://www.radgametools.com/bnkdown.htm
Also the trialware EO Video can convert from Quicktime to AVI or MPEG1.
EO Video homepage is http://www.eo-video.com/
Martin. -
Installed Rad Video Tools and followed the guide on this site. It appears to do the conversion but when I try to view the converted file it's still not right (plays back at same FPS as orig - even if I try to change the FPS).
Patrick
Originally Posted by zedolfblack -
I've always had the VFAPI codec installed before i put QTReader.vfp in the TMPGEnc folder. Is it necessary if the plugin is in the same directory as the application?
Did you install VFAPI codec?
http://www.divx-digest.com/software/vfapi.html -
Well that didn't work either...
...looks like quicktime pro is the only way to go here ...right? $29.95
Patrick
Originally Posted by au7usa -
Don't know if it is the easiest way, but I used Virtual Dub (or one of the mods, I can't remember) to join several A70 movie clips and convert to AVI. Then I used TMPEGenc to convert to SVCD. I can't tell you the exact steps because I don't remember, but it did work.
QuickTime MOV to MPEG2 too dark
By bgtrix in forum Video ConversionReplies: 1Last Post: 16th Mar 2012, 12:36 -
mpeg2 decoder available quicktime alternative for use with MPEG Streamclip
By mattiebrownoz in forum Video ConversionReplies: 0Last Post: 9th Apr 2009, 20:08 -
Apple Quicktime Mpeg2 playback Component
By macuser1960 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Mar 2009, 12:33 -
encode a Keynote Quicktime movie to mpeg2 using ffmpegx possible?
By mkoehler in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2008, 10:16 -
Quicktime Alternative no longer has MPEG2 decoder for Streamclip use?
By vidvoo in forum Video ConversionReplies: 8Last Post: 15th Nov 2007, 18:42
