Hi, I have an AVI file encoded with Xvid. I've tried to convert it to VCD using TMPGEnc, Mainsource Encoder (which in the infor box said it was DirectShow Import), All Video Converter, AVI Converter, and WinMPG but they all crash a little more than 50% into the process.
GSpot says it is an OpenDML stream, and that I have 2 codecs for video installed and 4 for audio (mp3).
DirectShow render gives this info.
(S) --> AVI Splitter --> XviD MPEG-4 Video Decoder --> DivXG400 --> Subtitle Mixer --> (R)
(S) --> AVI Splitter --> Moonlight Odio Dekoda --> Morgan Stream Switcher --> (R)
Virtualdub says there is an improper VBR audio code.
Does anyone know what DirectShow Import AVI is or can anyone offer any insight?
Let me know if you need any more info.
Because your avi has VBR audio you will need to convert to PCM wav. Open the movie in Virtualdub, go to the audio menu and select "full processing mode", go to the file menu and select "save wav". Use the wav file in TMPGEnc as your audio source.
As for the video, try installing FFDSHOw. This usually helps TMPGEnc decode Xvid video. -
Have you checked for bad frames using Vdub ? This could be causing your encode to fall over half way through. Failing that try frameserving to TMPGenc from Vdub.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
A problem with Directshow and VirtualDub
By CrystalClear47 in forum Newbie / General discussionsReplies: 23Last Post: 7th Jun 2011, 02:34 -
Avi to dvd conversion problem
By Psco2007 in forum Authoring (DVD)Replies: 5Last Post: 28th Feb 2011, 12:34 -
problem with conversion from DV-AVI to DVD
By obadvw in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 17:08 -
DirectShow AVI Muxer + Infinite Pin Tee Woes
By JCipriani in forum ProgrammingReplies: 7Last Post: 5th Nov 2008, 17:52 -
DirectShow Filewriter Problem
By Ademar in forum ProgrammingReplies: 0Last Post: 6th Nov 2007, 09:47
