  1. I have a movie I've ripped to .vob files, which total 7.5GB in size
    I don't have the movie anymore but want to burn the files into a DVD. I tried Nero and selected DVD but soon found out the .vob files totalled 7.5GB, what do I do?
    Monroe, Mi
    to burn it, you have to shink the files down to approx 4.37gb so it will fit on a dvdr. use dvdshrink, just open the files and compress the video down.
  3. How did they get so large in the first place though?
    Dec 2002
    My Swamp
    If you have only got .vobs you may need to author them.
  5. Originally Posted by AgaBoogaBoo
    if you would have spend the same amount of time learning how to post a question you would all ready know the answer to this one.....
    How Big A Boy Are Ya?
  6. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    The process of ripping the DVD is a very violent process and bumps and bruises and other injuries can occur to the VOB...they are probably just a little swelled up, throw a couple of asprins in the A drive, and put some ice on the mouse...the swelling should go down in a few days.
